xcube
Aug 26, 2012Aspirant
ReadyNas Duo v2 wont power up (5.3.5)
Hello, I believe that I have found a bug with the latest Radiator 5.3.5, my ReadyNAS Duo 2 wasn't able to power up after I did the following: 1) Go to Settings> Power 2) Enable Power Timer 3...
petepewter
Aug 31, 2012Aspirant
Similar problem. NV+ v2
I've got the power timer set. Sometimes it will shutdown and restart as programmed. Sometimes I can manually restart after an auto shutdown. Other times it doesn't auto start or let me manually restart. If I unplug the mains and reconnect, works fine again. Can't spot a pattern yet.
After reading forum I manually reinstalled Raidar 5.3.5, but I noticed at the time that it was already on the later uboot already.
U-Boot 1.1.4 (Feb 6 2012 - 14:42:36) Marvell version: 3.4.27
Netgear version: Uboot-1_1_4-NetgearNV+V4-V1008
Didn't notice any improvement. Still intermittent at turning on and off and locking up the power button.
what's next to try please? Thanks
