xcube
Aug 26, 2012Aspirant
ReadyNas Duo v2 wont power up (5.3.5)
Hello, I believe that I have found a bug with the latest Radiator 5.3.5, my ReadyNAS Duo 2 wasn't able to power up after I did the following: 1) Go to Settings> Power 2) Enable Power Timer 3...
mdgm-ntgr
Oct 19, 2012NETGEAR Employee Retired
Sounds like the u-boot probably wasn't updated on your system. When you get the replacement check to make sure the u-boot is updated. If it isn't install 5.3.6 over the top of itself: http://www.readynas.com/RAIDiator_arm_5_3_6_Notes
