Mefist
Nov 22, 2018Aspirant
readynas DUO V2
It does NOT connect to the computer ((((Not through a network cable. Not via USB 3.0. Why?
Mefist
SMB1 is enabled. Through the router everything works. Directly to the computer can not connect ((( Windows 10 x64
How to connect directly?
Sandshark
Nov 22, 2018Sensei
Well, through the router is the way it is intended to function. It is, after all, a Network Attached Storage unit. And unless your router does not support gigabit Ethernet, it will be no faster when connected directly.
But if you want to do it, you will have to manually assign IP addresses to both your computer and the NAS that are within the same IP sub-net (all but the last number are the same). I don't recommend this for anyone who was not already aware of the requirement (which is not unique to a NAS).
- MefistNov 22, 2018Aspirant
Here the program shows what works, but there is no connection (((I don’t know how to disable DHCP mod
- SandsharkNov 22, 2018Sensei
You will have to wait for a Netgear moderator to enable the picture before anyone else can help.
Happened ))))
Set up a direct connection))))
Computer settings for direct Readynas v2 Duo connection:
IP adress: 192.168.168.169
Subnet mask: 255.255.255.0
Default gatawey: 192.168.168.168Perfect DNS: 192.168.168.168
