Retired_Member
May 10, 2020READYNAS Duo v2
Can anybody help? I'm trying to setup a backup on my ReadyNAS as follows: Source: ReadyNAS/USB_HDD_1 Destination: MyPC/u$/ReadyNAS When it starts backing up, instead of backuping up to U:\Re...
May 10, 2020Guru - Experienced User
Share the ReadyNAS folder on the PC, and drop the U$ in the backup job configuration.
- Retired_MemberMay 10, 2020
I would like to use the built in Administrator share u$ if possible.
If I go the opposite way from MyPC/u$ to the ReadyNAS it works fine.
- StephenBMay 10, 2020Guru - Experienced User
Why?
FWIW, you could alternatively access the share using u$ from another Windows PC in file explorer, and note the full path name there.
- SandsharkMay 11, 2020Sensei
U$ is a local variable on the PC. The NAS has no idea what it's value is and it does not pass in a Linux based backup job as a variable name the PC can fill in. So, it's taken literally. You need to replace it with it's value on the PC. StephenB has suggested one way to figure that out.
