BriMill
Sep 24, 2018Tutor
ReadyNAS Duo V2/Logitech Media Server/RAIDiator v5.3.13
Hi,
Note to Netgear - your product support is so poor you're less likely to win returning customers than syphilis!
Before I bin the painfully dire contraption that is the ReadyNAS Duo V2 I th...
- Sep 24, 2018
Well, use internet explorer....
Mine works and i did exactly as i wrote abobe.
// Hans
viperhansa
Sep 24, 2018Virtuoso
HI..
Your Nas is ARM based..
It's simple to install LMS on it, i'm running excactly the same setup.
You can find it here:
https://www.mysqueezebox.com/download
install is pretty forward, you upload it from apps page on your nas.
Regards
Hans
BriMill
Sep 24, 2018Tutor
I have tried a number of versions of LMS, old and recent, and get the same error message each time, which is: an unexpected server error occurred.
The legacy versions of LMS are here:
http://downloads.slimdevices.com
I read elsewhere from a Netgear employee that the most recent versions of LMS will only run if I migrate to the most recent operating system, i.e. away from RAIDiator which I would rather avoid.
- viperhansaSep 24, 2018Virtuoso
// Hans
- BriMillSep 24, 2018Tutor
Many thanks wise luminary!
Youre welcome!
Good luck! :-)
