peterhugill
Jul 27, 2011Aspirant
ReadyNAS Duo very very slow
Need help before i put it in the bin, Got a Readynas Duo 4TB installed accross 2 drives. Problem is its very slow when accessing Videos and Pictures as it may take 1min or 2min to load a picture ...
sphardy1
Jul 28, 2011Apprentice
In a cmd window type: ipconfig -all
In the output you should see something like this - the description field describing the NIC installed (In my case an Intel NIC)
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/1000 MT Desktop Adapter
Physical Address. . . . . . . . . : 08-00-27-92-D2-6F
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
