skt
Dec 26, 2011Aspirant
ReadyNAS Duo with APC ES 450 UPS
Goal: Protect Duo against improper shutdown due to power failure. Current situation: Duo power cord plugged into APC UPS unit along with some other hardware (external drives, monitor). UPS monitored...
Dec 28, 2011Guru - Experienced User
If you use this, don't forget to connect your ethernet switch/router power to the same UPS! Otherwise the NAS won't shut down when the UPS battery drains.
bbaraniec wrote: Option "Enable monitoring of UPS physically attached to a remote ReadyNAS" allows you to have 2 or more ReadyNas units (or PC) monitored and shutdown via network.
