SthFitz
Aug 12, 2012Follower
ReadyNAS Duo won't boot after 4.1.9 upgrade- #19121497
My ReadNAS Duo V1 has been turned into a virtual boat anchor after doing a standard upgrade to OS 4.1.9. I can't see it on RAIDar 4.3.4, I can't access it on Windows Explorer (Windows 7-64) although ...
machv
Aug 16, 2012Aspirant
I'm just off on holiday for the next 4 days so I'll set this up on my return. If there is some more detailed instruction as to how to set up port forwarding to you I would be grateful.
