SthFitz
Aug 12, 2012Follower
ReadyNAS Duo won't boot after 4.1.9 upgrade- #19121497
My ReadNAS Duo V1 has been turned into a virtual boat anchor after doing a standard upgrade to OS 4.1.9. I can't see it on RAIDar 4.3.4, I can't access it on Windows Explorer (Windows 7-64) although ...
mdgm-ntgr
Aug 16, 2012NETGEAR Employee Retired
Depends on the router you have. You assign the MAC address of the NAS a static IP in the router's settings and port forward port 23 to that.
Another option is to give support the 5 digit ID shown in RAIDar when in tech support mode.
