SthFitz
Aug 12, 2012Follower
ReadyNAS Duo won't boot after 4.1.9 upgrade- #19121497
My ReadNAS Duo V1 has been turned into a virtual boat anchor after doing a standard upgrade to OS 4.1.9. I can't see it on RAIDar 4.3.4, I can't access it on Windows Explorer (Windows 7-64) although ...
jeffdahl
Aug 17, 2012Aspirant
Same issue here-- after auto-upgrade to 4.1.9, NFS mounts are read-only. Will downgrade fix the problem?
