SthFitz
Aug 12, 2012Follower
ReadyNAS Duo won't boot after 4.1.9 upgrade- #19121497
My ReadNAS Duo V1 has been turned into a virtual boat anchor after doing a standard upgrade to OS 4.1.9. I can't see it on RAIDar 4.3.4, I can't access it on Windows Explorer (Windows 7-64) although ...
mdgm-ntgr
Aug 17, 2012NETGEAR Employee Retired
How is NFS mounts read-only the same as the NAS not booting?
You could try downgrading to 4.1.8 or updating to 4.1.10 beta. You may then need to reset the ownership and permission on the share via the Advanced Options tab.
