SthFitz
Aug 12, 2012Follower
ReadyNAS Duo won't boot after 4.1.9 upgrade- #19121497
My ReadNAS Duo V1 has been turned into a virtual boat anchor after doing a standard upgrade to OS 4.1.9. I can't see it on RAIDar 4.3.4, I can't access it on Windows Explorer (Windows 7-64) although ...
Rabbie
Aug 20, 2012Aspirant
Remote host still unreachable.
Whether the WAN ip was changed? Or the system was powered off?
You also can install the teamviewer, then post the ID#/password in case#19205239. Then we can remote access your pc.
