gpolkga
Aug 16, 2012Aspirant
ReadyNAS Duo won't boot after 4.1.9 upgrade #19206828
I have the same exact problem as #19121497. Opened new under #19206828. Haven't heard anything from tech support. Anybody have any resolution on this?
Rabbie
Aug 17, 2012Aspirant
Before some system files and process are in memory. When you update the ifrmware, you must reboot the device. So it will re-read the system files from disks. But disk failed, so failed read the files and failed boot up.
You also can check the disk with disk vendor's tool.
