gpolkga
Aug 16, 2012Aspirant
ReadyNAS Duo won't boot after 4.1.9 upgrade #19206828
I have the same exact problem as #19121497. Opened new under #19206828. Haven't heard anything from tech support. Anybody have any resolution on this?
mdgm-ntgr
Aug 19, 2012NETGEAR Employee Retired
Test the disk properly using this: http://www.readynas.com/kb/faq/hardware/how_can_i_verify_that_my_disk_is_bad
If you get the same issue with another disk in the same slot in the NAS and it tests fine then you'd suspect a problem with the NAS chassis. For now though I would suspect the problem is the disk.
