b4pjoe
Sep 01, 2015Aspirant
ReadyNAS Duo won't boot
Info on bottom says RND2110v2. I bought this unit used a couple of years ago and it worked fine until about 6 months ago and it would not start up. I suspected a power brick issue but at the time...
b4pjoe
No it is not showing in RAIDar. The light at the network port is not on which I think would mean it won't show up on the network. The old IP was in the 192.168.1.x range and it never showed up there so changed my IP on the PC to 192.168.168.167 but it still didn't see it.
