motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
atanas2
Hi,
Can you download the file and then upgrade the firmware using the local image. In this way the unit will verify the image file first for errors. if you already tried this, go ahead and do OS-re install first.
