motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
motah33
Thanks for the reply. Yes, I've tried this method before and it hasn't worked. OS re-install sounds a bit of a job. I've got a lot of stuff on there. Is this the only way to fix this problem? Any idea as to why it might be failing to update?
