motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
motah33
Oct 20, 2012Aspirant
Thanks for the reply. Just running it now... If it is the memory would that explain the USB issue too or are they unrelated? I've never used the USB ports until now (with the UPS). Netgear support has got back and asked to do a full factory reset. I would like to try whatever checks I can before doing that. The data has been backed-up including the configuration file.
