motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
mdgm-ntgr
Oct 21, 2012NETGEAR Employee Retired
It's possible that bad memory would prevent a firmware update from working. If the memory is fine, then further investigation would be needed. There's a good explanation of the memory test on the Duo here: http://www.readynas.com/forum/viewtopic.php?f=11&t=26993
