motah33
Oct 12, 2012Aspirant
ReadyNAS Duo won't update with latest firmware
Hi, I've had this problem for a while. Every time I try to upgrade the firmaware using the GUI, I eventually get a message back saying that the update failed: Fri Oct 12 17:12:13 WEST 2012 Probl...
motah33
Oct 21, 2012Aspirant
It's been running for a while now and I noticed the squence with the disk1/disk2 leds went as follows: 10-01-11-00 (I think). Then, the act led came on and the disk1/disk2 leds went off. It's been stuck in this state for a long, long time whereas the other sequences went quite quickly. I don't know if the tests are any differenct with the act led on but it certainly stuck here. If this is signifying a memory problem, then what is the spec of original memory in the Duo so that I can get a replacement?
