2trees
Aug 22, 2013Aspirant
ReadyNAS Duo
The subject is in accordance with the Unit Label, but I am advised by Technical Support that from the serial # submitted it is in fact v1 !! Firstly I must say that I am extremely frustrated by the to...
Aug 22, 2013Guru - Experienced User
Then if there is no data on the NAS that you care about, try wiping the disks on PC (or doing the full factory reset procedure).
What IP address does RAIDar tell you the NAS is using? Do you know that IP address your PC is assigned?
