2trees
Aug 22, 2013Aspirant
ReadyNAS Duo
The subject is in accordance with the Unit Label, but I am advised by Technical Support that from the serial # submitted it is in fact v1 !! Firstly I must say that I am extremely frustrated by the to...
Aug 22, 2013Guru - Experienced User
Is 192.168.1.102 the NAS or the PC?
If the drives are both wiped, reinstall them and start up the Nas. It will install the firmware onto the drives, and then the default admin password would be netgear1. To set it up, you'd connect to https://nasip/admin. Firefox is probably the best browser to use. You will need to click through a security exception.
