2trees
Aug 22, 2013Aspirant
ReadyNAS Duo
The subject is in accordance with the Unit Label, but I am advised by Technical Support that from the serial # submitted it is in fact v1 !! Firstly I must say that I am extremely frustrated by the to...
Aug 25, 2013Guru - Experienced User
Well, what you are describing is the normal frontview log on screen. What is wrong is that it isn't accepting your log on. What browser are you using?
