2trees
Aug 22, 2013Aspirant
ReadyNAS Duo
The subject is in accordance with the Unit Label, but I am advised by Technical Support that from the serial # submitted it is in fact v1 !! Firstly I must say that I am extremely frustrated by the to...
vandermerwe
Aug 25, 2013Master
2trees, did you confirm that you have a v1?
The default passŵord for the v1 is netgear1, for the v2 it is password.
I'll assume you have a v1, I'd suggest you factory default the unit:
http://www.readynas.com/download/docume ... 0Nov11.pdf
It's described on pages 15-16 of the manual(link above)
When you factory default the unit will lose its fixed IP address and will try to obtain an ip,address from a dhcp server or will set an IP address of 192.168.168.168. You will need to consider this when reconnecting to the NAS.
