NoopyKat1's avatar
NoopyKat1
ReadyNAS DuoV1 - Post 4.1.12 Upgrade no SSH, Frontview, etc.
I have ready through most of the posts and after seeing that none had all of the problems I have, decided to ask for help.
Sunday I decided to upgrade my ReadyNAS Duo V1 from 4.1.10 to 4.1.12. I had no add-ons installed and after checking the Logs to see that there were no errors, alerts, etc., decided to go ahead with the upgrade. After the firmware was loaded and validated, the upgrade proceeded without any problems (or at least that's what I thought) but when I tried to login to check that all the settings were still intact, I realized there were problems.
I was able to login without a problem but when I went to check the "Health" and "Logs" tabs, they were blank with the exception of a the "Clear Logs" and "Download logs". Clicking on these buttons had no effect. I was able to access most of the other tabs and sections but I couldn't see anything on the Health and Logs tabs so I thought I would install the enableRootSSH to see if I could figure out what was happening in the background. When I installed the package, I noticed that it didn't show up in the "add-ons" so I rebooted the NAS a few times hoping it would show up in the "add-ons" and that the missing content on the tabs would suddenly show up. I eventually figured out that the add-on didn't show up so I was about to start troubleshooting the firmware update issues when I thought I would reboot one more time. Suddenly, I had no access to Frontview, SSH, RAIDar, etc. so I thought I would hold the power button down to force a graceful shutdown. This process went fine and this morning I checked the NAS and although there is no disc activity, I still cannot access the NAS whether I use Frontview, SSH, RAIDar or even to ping the Ethernet port.
I could pull one of the drives out and copy the contents to another drive and then erase both drives and perform a factory reset but I want to avoid this. Does anyone have an idea or suggestion which may fix this ? As I said, there were no add-ons except for the SSH module and I have a static IP assigned. When trying to access via SSH, I get a "Network Error: Connection timed out" and if I ping the interface, I get "Host unreachable".
Thank you in advance for any advice.
  • Hi all, just a brief message to thank 'mdgm' for the help in sorting out the 4.1.12 upgrade issue.
    For those who have the same issue, my advice would be look in the tmp folders for part downloaded files. Not sure how it happened, but I have a couple of part downloaded files which seem to have caused issues.
ProSupport for Business
