nsne
May 25, 2017Virtuoso
ReadyNAS error: "mount_block_root+1f1"
After installing the 6.7.3 firmware (6.7.1 > 6.7.3 upgrade), I'm seeing the error message "mount_block_root+1f1" on the LCD. I was going to try the USB Recovery method, but I saw in this similar thre...
- May 30, 2017
USB Recovery with a variety of thumb drives, syslinux.exe versions and 6.7.3/4 didn't work on the unit that was having trouble.
Netgear sent a replacement 314, and the USB Recovery process worked great (on the first try!) for updating the firmware.
So the problem was that 6.7.3 effectively bricked my unit.
mdgm-ntgr
May 25, 2017NETGEAR Employee Retired
USB Boot Recovery is the solution. Be sure to right click on usbrecovery.exe and select Run as Administrator.
If USB Boot Recovery doesn't work for you you can try multiple USB keys. Some USB keys are incompatible.
Some users who've had trouble with creating a USB Boot Recovery key with usbrecovery.exe have had success with Rufus
With Rufus you'd select the MBR partition scheme for BIOS or UEFI and select FAT32 as the filesystem (default) and the default cluster size.
Once the mount_block_root error is dealt with if there are any remaining issues we can see whether we can look into those.
nsne
It's not working. I tried using a 4GB SanDisk Cruzer, but the 314 kept booting as normal even though I was holding the Backup button. That resulted in the "mount_block_root+1f1" error.
Tried formatting the same USB drive using Rufus, but the instructions were unclear. Is "FreeDOS" the right choice? Do I run Rufus and then run usbrecovery.exe? Do I transfer the contents of a USB created with usbrecovery.exe to a Rufus-formatted USB?
Then I tried a Patriot 8GB USB drive. Now the 314 is in this weird state where it says "Netgear Storage / Welcome [ ]" and the power button is flashing. There doesn't appear to be any USB disk activity.
- mdgm-ntgrMay 25, 2017NETGEAR Employee Retired
The disk needs to be syslinux bootable.
The same contents of the x86 folder that usbrecovery.exe puts on the USB key need to be put on the USB key.
Rufus should put the syslinux boot loader on the USB key itself if you chose the correct option.
- mdgm-ntgrMay 26, 2017NETGEAR Employee Retired
If you have updated to 6.7.3 and ran into this issue please try USB Boot Recovery with ReadyNAS OS 6.7.4 which is now available!
If you have not yet upgraded please upgrade to 6.7.4 rather than 6.7.3. If your system has already been fixed I would still suggest updating to 6.7.4 the normal way using the web admin GUI.
If you can't do USB Boot Recovery despite trying multiple different USB keys and following the directions you'll need to contact support.
- nsneMay 30, 2017Virtuoso
