Aevans0001
Sep 01, 2018Tutor
Readynas Failed after Scrub
Model Rn214
OS 6.9.3
Ok so I was experiencing sluggish behaivor, which I attributed to a lot of read and writes. I decided to try a scrub which I had never done before (1.5 years). The scru...
- Sep 13, 2018
I decided to just start a new. I figured I probably messed it up worse before I sent the logs, so I didn't see the reason to pay the extra money.
Sep 03, 2018Guru - Experienced User
Marc_V wrote:
You have to purchase the OnCall 24x7 not the GearHead. GearHead Contracts are usually for Home Networking Support.
Something that really needs to be fixed on the support site. If you don't happen to know this, you can easily purchase the wrong thing.
Aevans0001
Sep 13, 2018Tutor
