RossB1
Jun 02, 2018Aspirant
ReadyNAS Issues with startup
Hi, my Ready NAS Duo with 2x2TB disks is gettign a bit old. Yesterday, after a power outage the unit rebooted and went into RAID Sync. When it finished I could not see the NAS on my network, nor coul...
- Aug 16, 2018
The next step is to back up the data - especially if disk 2 is also fairly old.
Once that is taken care of, you can hot-insert a new disk 1. After that resyncs, everything will be back to normal.
RossB1 wrote:
I have an unused HCL approved spare HDD ST2000DM001 sitting around. This is the same as the disk in the ReadyNAS.
They are on the HCL, but the Barracuda drives don't have a good reputation reliability in RAID arrays. The 3 TB drive seems particularly trouble-prone, so it's possible that the other drives in the family don't deserve that reputation. Once you have a backup, there's no reason not to use the Barracuda you already have.
Though generally I recommend NAS-purposed drives (WDC Red or Seagate Ironwolf) or (if more performance is needed) enterprise class. I use mostly WDC Reds myself. I have a duo v1, it has a WD20EFZX ( 2 TB Red) and an older Seagte (I don't recall the model off-hand).
RossB1
Aug 16, 2018Aspirant
Is it worth trying an OS reinstall form the Boot Menu? Is there a risk that I might lose data doing this? I guess I coould remove 1 disk and keep it aside.
Aug 16, 2018Guru - Experienced User
An OS-reinstall is generally safe, but I don't think it will help. There are some situations (particularly a full OS partition) where it can make things worse.
I suggest powering down the NAS and removing disk 1. Power up, and see if it boots normally (with file access). If that fails, then power down again, and try this test with only disk 2 in place (in slot 2, don't move it to slot 1).
If either of these works, then the next step is to offload the data. Don't try reinserting the missing disk. The fastest way to offload is to copy the data to a PC that is connected with ethernet.
Then I'd recommend testing both disks in a Windows PC, using vendor tools (Seatools for Seagate, Lifeguard for Western Digital).
