RossB1
Jun 02, 2018Aspirant
ReadyNAS Issues with startup
Hi, my Ready NAS Duo with 2x2TB disks is gettign a bit old. Yesterday, after a power outage the unit rebooted and went into RAID Sync. When it finished I could not see the NAS on my network, nor coul...
- Aug 16, 2018
The next step is to back up the data - especially if disk 2 is also fairly old.
Once that is taken care of, you can hot-insert a new disk 1. After that resyncs, everything will be back to normal.
RossB1 wrote:
I have an unused HCL approved spare HDD ST2000DM001 sitting around. This is the same as the disk in the ReadyNAS.
They are on the HCL, but the Barracuda drives don't have a good reputation reliability in RAID arrays. The 3 TB drive seems particularly trouble-prone, so it's possible that the other drives in the family don't deserve that reputation. Once you have a backup, there's no reason not to use the Barracuda you already have.
Though generally I recommend NAS-purposed drives (WDC Red or Seagate Ironwolf) or (if more performance is needed) enterprise class. I use mostly WDC Reds myself. I have a duo v1, it has a WD20EFZX ( 2 TB Red) and an older Seagte (I don't recall the model off-hand).
RossB1
Aug 16, 2018Aspirant
Hi StephenB, I powered down, took out Disk 1 and rebooted. After a long volume scan I have now regained access to my device and data, albeit on one drive. Disk 1 slot is currently empty.
The old Disk 1 is a WD20EARS that I've had in the machine since new. Must be 8 or 9 years old.
What do you recommend as next step? I have an unused HCL approved spare HDD ST2000DM001 sitting around. This is the same as the disk in the ReadyNAS.
Thank you for your great guidance so far. Really appreciate it.
Ross
Aug 16, 2018Guru - Experienced User
