poko2121
Jan 05, 2016Aspirant
readynas mapped drive keeps disconnecting
Hi everyone, I have a readynas 312 running os 6 and I have an issue where mapped network drives to the readynas constantly disconnect. Even while using a file I'll go to save it and it won't allow i...
poko2121
SMB, Rsync, UPnP, HTTP, HTTPS, Antivirus
mdgm-ntgr
Jan 05, 2016NETGEAR Employee Retired
There is a known issue at the moment with anti-virus. If you disable that, does that resolve your problem?
- poko2121Jan 11, 2016Aspirant
tried it but I'm still constantly getting disconnected. Even mid file transfer. I'm many times unable to save files from both mac and windows computers because the server is no longer available when I'm ready to save
- mdgm-ntgrJan 12, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- poko2121Jan 12, 2016Aspirant
I just emailed them over
Thank you
You are getting a lot of dropped packets. You could try changing ethernet cables, try a different port on your router/switch etc.
- StephenBJan 13, 2016Guru - Experienced User
Is this a straight ethernet connection (all the way to the PCs) or is there something else on the path (wifi or powerline)?
