poko2121
Jan 05, 2016Aspirant
readynas mapped drive keeps disconnecting
Hi everyone, I have a readynas 312 running os 6 and I have an issue where mapped network drives to the readynas constantly disconnect. Even while using a file I'll go to save it and it won't allow i...
poko2121
Jan 13, 2016Aspirant
it's not a managed switch. I'll try flow control but it does the same thing when accessing through vpn. it usually doesn't connect
poko2121
Jan 22, 2016Aspirant
Tried the flow control and still getting the issue. My mac computer is alwasy able to connect and hold a connection but the 3 windows computers all have disconnection issues and are usually not able to connect for a few min every half hour.
Is there something else I could try?
Thank you
- StephenBJan 22, 2016Guru - Experienced User
Is the Mac using AFP or CIFS? Is it connected to the same switch as the Windows PCs?
