poko2121
Jan 05, 2016Aspirant
readynas mapped drive keeps disconnecting
Hi everyone, I have a readynas 312 running os 6 and I have an issue where mapped network drives to the readynas constantly disconnect. Even while using a file I'll go to save it and it won't allow i...
poko2121
Jan 22, 2016Aspirant
Tried the flow control and still getting the issue. My mac computer is alwasy able to connect and hold a connection but the 3 windows computers all have disconnection issues and are usually not able to connect for a few min every half hour.
Is there something else I could try?
Thank you
Jan 22, 2016Guru - Experienced User
Is the Mac using AFP or CIFS? Is it connected to the same switch as the Windows PCs?
- poko2121Jan 22, 2016Aspirant
Everything is using SMB and all on the same switch
- StephenBJan 22, 2016Guru - Experienced User
You could possibly try using the SMB plus to configure the NAS to use older SMB protocols.
Though the packet loss issue on the NAS still would hurt performance.
why would it only affect the windows computers though? And how do I configure the SMB plus?
