cluewy
Mar 25, 2016Aspirant
ReadyNas media and iTunes
Hi, I have my media stored on a single share on my ReadyNas Duov2: /media/Music /media/Videos I have mounted this as a drive in Windows, allowing iTunes to access my media and then manage i...
Mar 25, 2016Guru - Experienced User
iTunes isn't creating new folders. or moving your media files - it is simply creating assigning those categories to each media file in its database. At least it doesn't move my media files around...
You can tell it the category you want by right-clicking on the media in iTunes and clicking "get info". Then choose "options" and you will find a "media kind" pulldown where you can set it.
How is the Samsung accessing the media? If it is using ReadyDLNA, then iTunes has nothing to do with it.
cluewy
Apr 03, 2016Aspirant
Hey thanks for the reply!
Samsung is using the ReadyDLNA, although I find that I have to regularly reboot for the Samsung to stay refreshed - for some reason the DLNA doesn't seem to refresh regularly (eg every 5/10/30 mins). Also get som contention between Samsung and Sony TVs which will also work but seem to be mutually exclusive and require a reboot between accessing them.
Any thoughts?
Thanks,
Chris
