I4getit
Oct 31, 2016Aspirant
readynas not providing power to bay 1
Hi, My readynas pro 4 will not reconise any drive i put in bay 1. This includes drives working fine in other bays. I dont beleive the drive is even spining up. (power issue?) I have tried hot ...
Oct 31, 2016Guru - Experienced User
Is it under warranty? That would be 5 years from purchase (if you are the original purchaser).
If not, I think you now have a Pro 3.
I4getit
Could it be a patition issue,
i get the same issue with bay 2 when i hot swap a replacement drive.
it wont take new drive, but will rebuild on failing drive if i reinsert it.
Fontveiw still report old drive in bay 2, even tho ive replaced it.
my replacement drives are ex zfs volumes.
- StephenBOct 31, 2016Guru - Experienced User
??? The NAS needs to reformat them when you insert them.
I don't think so. Though the new drives do need to have at least the same number of sectors as the old ones, otherwise they can't be added to the array.
You could try zeroing one of the replacements, powering down the NAS and inserting it in slot 1 with all other drives removed. Then see if the NAS does a factory install.
- I4getitOct 31, 2016Aspirant
zeroing replacment drive now
