Zebedee1's avatar
Sep 20, 2015
ReadyNas not showing up
Hi
I have a ReadyNas RN10400 connected to a TP-link archer c7 wireless modem router. I have two laptops. A Dell inspiron 32bit and a Dell Studio 64Bit both running Win 7 and connecting to the router via wireless. If I turn either one on it sees the NAS and The NAS shows up under network and in explorer. But if I turn both on depending on which one I turn on first is the one that sees  the NAS and the other one doesn't.
Have I got a setting wrong or something.
Thank you
  • I think I may have solved it. Both computers were named the same. Changing the Computer Name on one of them and restarting it the NAS is now showing up. Hopefully it will stay this way.
    Thank you
  • There has been an issue with this for some time, it's sometimes related to master browser allocation. I thought it had been fixed in 6.2.4.
    Check that the workgroup setting is the same for all devices and that there is no IP address conflict.
    What firmware is on the readynas?
    Can you access the nas by using a browser ipaddressofnas/admin or using raidar?
    • Zebedee1's avatar
      Zebedee1
      Tutor
      Hi
      Thank you for replying
      Firmware version 6.2.5
      Can't see any IP conflicts
      Yes can access the NAS via browser
      Thank you
      • Zebedee1's avatar
        Zebedee1
        Tutor
        Thank you
ProSupport for Business
