erskinejohn
Aug 11, 2017Aspirant
READYNAS NV + V2 - Volume has disappeared after failed resync
READYNAS NV+ V2 running Reported disc3 failure, replaced 2tb disc with 4tb WD Red, resync started then failed with errors below and disc4 flashing! Wasn't doing anything, adjusted volume size displaye...
Marty_M
Aug 17, 2017NETGEAR Employee Retired
Hello erskinejohn,
There is a possibility that while the new hard drive was on a sync process the another hard drive failed that brought the volume down. Can the raidar still detect the NAS from the network? Can you still download the complete the logs and provide us the copy, you may use file sharing website like wikisend and PM me the download link.
Welcome to the community!
Marty_M
NETGEAR Community Team
- erskinejohnAug 17, 2017Aspirant
I will start it up again and try RAIDAR. What will that tell me? I can still access the admin page - that's how I got the log excerpt. I'm fairly sure you are correct with Hard Drive 4 being the suspected culprit.
Yes, I can see it in RAIDAR - even shows status as HEALTHY! I would beg to differ....
password johne
Pretty sure that's the culprit then. All other disks show ZERO, but this now displays as OK in Admin page and healthy on RAIDAR. What to do to restore the volume? I have a replacement HDD to swap in as soon as it's back up. I'm sure I'm in warranty for the faulty WD Red too..........
- Marty_MAug 20, 2017NETGEAR Employee Retired
Hello erskinejohn,
Based on the logs disk 4 is faulty. There is possibility the while the replacement hard drive for the disk 3 was syncing, disk 4 failed and now the volume is down. This concern may require assistance from our engineers and/or higher tier who can remote in to the NAS and fix this from the backend. The process may require data recovery contract you may contact our support to avail the contract.
Marty_M
NETGEAR Community Team- erskinejohnSep 11, 2017Aspirant
Hi
Can you get the relevant team to contact me, please? It's still the middle of wedding season so working round not having the NAS is alreaqdy causing me additional work/issues so have even less time to waste. As long as someone can explain the costs, that's fine.
Thanks
J
- Marty_MAug 24, 2017NETGEAR Employee Retired
Hello erskinejohn,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
