erskinejohn
Aug 11, 2017Aspirant
READYNAS NV + V2 - Volume has disappeared after failed resync
READYNAS NV+ V2 running Reported disc3 failure, replaced 2tb disc with 4tb WD Red, resync started then failed with errors below and disc4 flashing! Wasn't doing anything, adjusted volume size displaye...
erskinejohn
Aug 17, 2017Aspirant
Pretty sure that's the culprit then. All other disks show ZERO, but this now displays as OK in Admin page and healthy on RAIDAR. What to do to restore the volume? I have a replacement HDD to swap in as soon as it's back up. I'm sure I'm in warranty for the faulty WD Red too..........
Marty_M
Aug 20, 2017NETGEAR Employee Retired
Hello erskinejohn,
Based on the logs disk 4 is faulty. There is possibility the while the replacement hard drive for the disk 3 was syncing, disk 4 failed and now the volume is down. This concern may require assistance from our engineers and/or higher tier who can remote in to the NAS and fix this from the backend. The process may require data recovery contract you may contact our support to avail the contract.
Marty_M
NETGEAR Community Team
- erskinejohnSep 11, 2017Aspirant
Hi
Can you get the relevant team to contact me, please? It's still the middle of wedding season so working round not having the NAS is alreaqdy causing me additional work/issues so have even less time to waste. As long as someone can explain the costs, that's fine.
Thanks
J
- StephenBSep 11, 2017Guru - Experienced User
I think you'll need to connect to support via my.netgear.com.
