dingo1
Mar 05, 2016Aspirant
ReadyNAS-NV (000DA2011431) dead
ReadyNAS-NV (000DA2011431) : My server died today (sniff) and its prolly the power supply as there is sign of life. I have another identical server without any disks that I've never used and I tried ...
dingo1
Mar 07, 2016Aspirant
Firstly, THANK YOU for the response!
I don't have the firmware info but it was the latest that the website would let me download.
Where is the firmware located?
Would I be better off moving the power supply of my spare unit to the one that won't run?
d
kohdee
Mar 07, 2016Administrator
Since your model/SN falls within the Service Action as notated by mdgm-ntgr, we can provide you (if we still have stock) a replacement PSU. I'd recommend just going with the PSU replacement instead of swapping your existing PSUs around (that way you don't end up with a dead weight NAS that can't even attempt to power on). If we don't have any PSU available, a support expert can work with you regarding your options.
- dingo1Mar 08, 2016Aspirant
I'd be very interested in that but I have very limited funds (living on Soc Security). Please look into that option for me.
I've been browsing on this site for similar problems and saw where someone was thinking it might be the battery in the machine. Do you think this is a possibility?
Thanks
d
- StephenBMar 08, 2016Guru - Experienced User
The replacement PSU should be completly free, since your NAS is part of the service action. You need to contact Netgear support yourself (support.netgear.com). You could use email. Make sure you provide the NAS serial number - I'd also say that you are covered by the service action, since the serial number is between 000DA2010FFE and 000DA2016000.
You should see some signs of powering up even if the battery needs replacing. Replacing the battery is not easy ( http://www.readynas.com/download/documentation/support/RESET_TIMER.pdf ). You are entitled to the replacement PSU, so I'd start with that.
- dingo1Mar 09, 2016Aspirant
Sir:
I'd VERY MUCH like to pursue the replacement solution. Can you please guide in what I need to do?
Thank!
Dale Wingo
- kohdeeMar 09, 2016Administrator
Hi Dale,
I see your Registration here on MyNETGEAR for this product. Can you confirm (yes/no) the address listed on your profile is the correct one to send the replacement to?
If so, I can process this for you.
Yes that is my address.
Thank you VERY much!
d
- hollinglApr 09, 2016Aspirant
I have just come across this post, as my NV+ has recently died. Its S/N is 000D-A201-53EA, so is in the range for the PSU service action as far as I can tell. Are you able to give me an email address I can contact support on to see if my region has a replacement PSU available, as I cannot track it down on support.netgear.com? Many thanks!
- StephenBApr 09, 2016Guru - Experienced User
register the NAS at mynetgear.com and then create an on-line support case for it.
- dingo1Apr 10, 2016Aspirant
Yes, what StephenB stated.
BTW - I just realized that I hadn't posted the conclusion on my sad story: I retried my set up the next day after jiggling the fan connector(s) and it started working. So I now have a working NAS!! I immediatled purchased a WD 6TB drive and now have duplicate copies of my data.
Thanks to all of you that helped - expecially the mods. GREAT service and is very much appreciated!
d
