Gerake
Nov 01, 2011Follower
ReadyNAS NV+ 4450 error 0x80070035 Network Path Wasn't Found
I Just got a this ReadyNAS from my school and nobody had any idea what it was, after some research, i realized i could backup everything i own onto this. When plugged into my router and running the RA...
ReadySECURE
Nov 03, 2011Apprentice
Hello,
You would want to access the admin interface at https://NAS_IP_address/admin. If the box is new to you, you may want to factory default the unit, this will erase any data on the unit and put it in a factory default state.
- http://www.readynas.com/kb/faq/boot/how ... ry_default
I also recommend reading the user manual for the NV+ just to get a better idea of the capabilities. Remember you can also open a case with support for questions as well.
- http://www.readynas.com/download/docume ... 9Nov07.pdf
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources -
Forums:
Knowledge base
