Gerake
Nov 01, 2011Follower
ReadyNAS NV+ 4450 error 0x80070035 Network Path Wasn't Found
I Just got a this ReadyNAS from my school and nobody had any idea what it was, after some research, i realized i could backup everything i own onto this. When plugged into my router and running the RA...
mdgm-ntgr
Jan 30, 2012NETGEAR Employee Retired
szlevi wrote: All I am saying is that the current CIFS stack is a buggy PoS in all curernt firmware - and you're really fooling yourself if you think they are not using the same codebase for all firmwares.
The versions of samba in sparc and x86 are very different. Just because the Sparc and x86 UIs look the same it doesn't mean they're the same underneath. If you look at the GPL (http://www.readynas.com/gpl) you'll find they're very different.
