immikemurphy
Oct 17, 2013Aspirant
ReadyNAS NV+ and Popcorn Hour C-200
I had great success with my Popcorn Hour A-110 pulling content from the NV+ so I picked up a Popcorn Hour C-200 to create a second set-up. When I browse the network on the C-200, it "sees" the NV+ ...
Oct 18, 2013Guru - Experienced User
You need ssh access to look at files on the OS partition. Though since your A-110 works fine, I am thinking it should not be necessary. Based on the old thread you linked in, it appears that the easiest solution is to use NFS to access the NAS. That would also give you better performance than SMB/CIFS
Are you using Share security or User security with the NAS? What firmware are you using?
