BruceBanner
Nov 02, 2014Aspirant
ReadyNAS NV+ blinking lights
hello, I haven't needed to even think about my ReadyNAS in so long that I forgot everything I ever learned! We had a power outage the other day followed by some brown outs then I am assuming a power s...
vandermerwe
Nov 02, 2014Master
That led pattern doesn't match the ones listed here:
http://www.readynas.com/download/docume ... AS-LED.pdf
, so difficult to know what it means.
Do you have a backup?
Perhaps power down, remove each disk and test it using vendor tools. Remember the slot numbers ( label the disks).
Alternatively or in addition, you could try booting the nas without disk 1, if it boots then that's your diagnosis. I'm not sure it is that simple though.
What firmware was running?
Can you access the boot menu, if so then also run a memory test.
