caddy512
Oct 26, 2019Aspirant
ReadyNAS NV+ Can Connect with RAIDar, but will not enter browse or admin page - Oct19
Hello, I have a old ReadyNAS NV+ and am trying to get it to connect to a new computer. I installed latest RAIDar version and it discovers the NV+ no problem. But it will not let me Browse or Ad...
Sandshark
Oct 26, 2019Sensei
Is your laptop IP in the 192.168.1.xxx subnet? (Open a command prompt and type IPCONFIG to find out.) If not, it sounds like the NAS is set up with a static IP outside the subnet of your router. That often happens if you set a static IP and then change routers. RAIDar uses an alternate discovery method that's not subnet-specific.
An OS re-install will reset the NAS to use DHCP and also reset the admin password to netgear1 (not password, as on newer models). Alternately, you can connect your laptop directly to the NAS via Cat5 cable and manually set the laptop IP to the 192.168.1.xxx range (Google has lots of articles on doing this).
Once you get into the GUI, turn off the static IP. Then, connect the NAS and PC back into your network, and re-boot both. You should now see the NAS at a different IP address, and you should be able to connect.
It is best to reserve an IP address in your router instead of setting a static IP in the NAS, specifically to avoid this issue in the future.
bedlam1
Oct 26, 2019Prodigy
Should'nt that be to the 192.168.168.xxx range?
