Dhiran
Apr 19, 2013Aspirant
ReadyNas NV+ Dead Drive
I have a 4 drive ReadyNAS NV+ and a drive in slot 2 reported it was dead. I have subsequently replaced the drive with a drive of the same size but the model had been superseded. Every time I insert th...
Apr 19, 2013Guru - Experienced User
Likely it won't have any partitions, however it is worth checking.
Right-click on "computer", and select "manage". Disk Management appears under storage (left pane). The disks will be listed on the right. If there are any partitions, right-click on them and delete them.
