Lestrad
Jun 06, 2016Aspirant
ReadyNAS NV+ Fails to Power Up after Power Failure
After a power outage that lasted a day and a half, my ReadyNAS NV+ won't power up. Should I assume the problem is the power supply and that it's just a coincidence that it died just when there was an...
- Jun 06, 2016
Hi Lestrad,
Have you tried using other power outlet(s) or power cord(s)? If ever you have already tried it, then I advise you to open an online case with NETGEAR Support. State what happened to your NAS and the troubleshooting steps we did to isolate the problem. A replacement power supply for your NAS might be process for you.
Check this article below as reference on how to replace the power supply unit of your ReadyNAS NV+:
ReadyNAS Replacement PSU guide
DaneA
NETGEAR Community Team
Lestrad
Okay, did that, but it still won't power on.
DaneA
Jun 06, 2016NETGEAR Employee Retired
Hi Lestrad,
DaneA
