brianworkman
Dec 10, 2015Aspirant
ReadyNAS NV+ flashing power button and stuck in booting
Yes, My wife is a photographer. She has a readyNAS nv+ that she used from many years. About two years ago, we bought a new unit and moved most of the current sessions she had to her new device....
mdgm-ntgr
Dec 10, 2015NETGEAR Employee Retired
What did those emails say about the error counts?
What brand and model disks are being used?
Can you power down the system, remove the disks (label order), connect them up to your PC and test them (e.g. test SeaGate disks using SeaTools and WD disks using WD Data Lifeguard Diagnostics)?
If data is important it should be backed up, especially if that data is irreplaceable (e.g. photos). There are things which can go wrong with any NAS/server that RAID cannot protect you against.
