BWA's avatar
BWA
Readynas NV+ Frontview Inaccessible. How to fix with Telnet?
I have a Readynas NV+ which no longer allows access to Frontview. This is more than likely related to log file size and my OS partition. I recently performed a factory reset and forgot to enable SSH ...
  • BWA's avatar
    BWA
    Oct 26, 2015
    Thanks for your help. It was that the log files were too large. I had a readynasremote.log file that was very large. Upon deleting this file, frontview was able to load.
    Thanks again,
    Booth
ProSupport for Business
