BWA
Oct 26, 2015Aspirant
Readynas NV+ Frontview Inaccessible. How to fix with Telnet?
I have a Readynas NV+ which no longer allows access to Frontview. This is more than likely related to log file size and my OS partition. I recently performed a factory reset and forgot to enable SSH ...
- Oct 26, 2015
Thanks for your help. It was that the log files were too large. I had a readynasremote.log file that was very large. Upon deleting this file, frontview was able to load.
Thanks again,
Booth
BWA
Thanks for quick reply. I did the above forementioned. Once I access the sysroot, do I need to delete the log files? Or is there anything else I should do.
THANKS!
BWA
For some reason it will not let me mount sysroot. Not sure why not...
- StephenBOct 26, 2015Guru - Experienced User
Are you getting an error?
Perhaps try
mount /dev/hdc1 /sysroot
- BWAOct 26, 2015Aspirant
Yes,
"Mounting /dev/md0 on /sysroot failed: Invalid argument "
I was able to mount using "mount /dev/hdc1 /sysroot"; however, I am not sure how I am supposed to get to the larger log/corrupted files. I run it as a DLNA server, which I am assuming may be causing some of the problems...
