BWA
Oct 26, 2015Aspirant
Readynas NV+ Frontview Inaccessible. How to fix with Telnet?
I have a Readynas NV+ which no longer allows access to Frontview. This is more than likely related to log file size and my OS partition. I recently performed a factory reset and forgot to enable SSH ...
- Oct 26, 2015
Thanks for your help. It was that the log files were too large. I had a readynasremote.log file that was very large. Upon deleting this file, frontview was able to load.
Thanks again,
Booth
Oct 26, 2015Guru - Experienced User
Go into sysroot, and then enter
df . -h
df . -i
The first command will tell you if the OS partition is out of space, the second will tell you if it is out of inodes.
You can look in /var/log and /var/cache/minidlna (adjusting for the mount point).
After you resolve it, there is toggle add-on what will move the minidlna cache to the c volume. That add-on is here: http://www.readynas.com/download/addons/4.1/Toggle
BWA
Thanks again,
Booth
