tknopp
Apr 05, 2017Follower
REadyNAS NV (Infrant-- Not NV+)
I am missing the documentation for the original Infrant Ready NAS NV (Model RNNVS2000). I am swapping out the disks, and ordered disks specified for NV+ v.1 before I realized my model number wa...
mdgm-ntgr
Apr 05, 2017NETGEAR Employee Retired
The NV+ v1 is an evolutionary improvement over the NV.
If a disk works in the NV+ v1 it most likely would work in the NV too, but that may not always be the case.
As TeknoJnky mentioned the maximum capacity disks you can use are 2TB disks. So you could install 4x2TB disks.
There are 4k physical and logical sector alignment.
From 4.1.7 onwards we'd use 4k sector physical partition alignment but the disks must still have 512b logical sectors.
If you need 4k sector physical partition alignment you may wish to backup your data, verify your backup, update to 4.1.7 (or later), verify the update is successful, do a factory reset with the new disks in place and restore your data from backup.
If the partitions aren't properly aligned then performance esp. write performance may be poor.
4k logical sector alignment is only available for OS6 systems (on 6.2.0 and later, I think). So you can't use disks with 4k logical sectors in your NV.
